intermittent to no spark on 1,3 and 5 cylinders
Alvin Hendricks
While trouble shooting a idle problem was checking the timing and found intermittent spark to 1 3 and 5 cylinders, engine is a 150 Mercury xr2 year 1986 checked wiring looks ok, thanks for help
moderator1
Re: intermittent to no spark on 1,3 and 5 cylinders
Moving to Mercury Questions.
mellowyellow
welcome aboard,<br />sounds like a bad power pack. the service manual<br />will give you the proper testing proceedure to<br />confirm this.<br />good luck,<br />M.Y.
Alvin Hendricks
Ok thanks for the guidance will check it out and let you know.
Alvin Hendricks
Got to work on xr2 today did a switch on the power packs and my no spark problem moved to 2 4 and 6 cylinders, looks like I am in the market for a power pack. Thanks for your help Mellow Yellow.<br /><br />Alvin Hendricks
Alvin Hendricks
