Burtonair01
Thread starter- Joined
- Oct 19, 2009
- 105
Re: Inverters
What brand inverter do you have? Sounds like thats the one I should have gone with, the switching back and forth atoumatically sounds like a real nice option. I'm sure we won't be using it very much really, just brew a pot of coffee in the morning and maybe nuke some lunch once in awhile and we will be running the motor often enough that we should'nt be running the batteries down, I hope!
I agree that two 12volt batteries will not last very long(maybe a day) if you're running that microwave around an hour a day and that coffee pot 1-2 hours a day. Given those batteries already have some draw on them. We've got a 2,000 watt inverter that runs a 46" tv, full size refrigerator, and some fans, lights, and a coffee pot. We have 6 6 volt golf cart batteries wired in series to get 12 volts and they will last 12 hours if we use our appliances moderately. You could give it a try and see how things go, no problem in getting another battery. Our inverter also has a built in switch that automatically switches from shore to inverter power when it looses shore power and also charges the batteries(110 amp built in charger) when we go back to shore power.
The inverter should have instructions that will tell you what gauge wire to use on the D/C side. We just have normal 12 gauge on the A/C side but ours is only 2,000 watts.
