I have an 80 gallon tank under the deck of my boat. I was getting trash in the carbs so I started siphoning the fuel out. I got a lot of water. I'm not sure where the water is getting in. Is there a way to test a poly tank for leaks without removing it? I can not remove the tank without cutting into the deck. If isn't leaking I'm considering cutting the tank in half to remove it and replacing it with a 40 gallon tank but if I can be sure the old tank isn't leaking I'll make due as it could be getting water through the sending unit, etc..
Thanks
Thanks
