Re: is sender for gas tank bad?
schematic,<br />i knew it was somehting like that. i took off the wire that was connected to the sender. i thought it was a (+). when i put it directly to the red on the battery, the needle went straight down....... the opporsite way. i sat there for a sec and then said........oh, darn, it must be a (-) so i did that and the need went full force to full. i took out the sender and called it a night. the mosquitoes were killin me. so, i cover it up and then will check the ohm on it tomorrow and then hopefully get that tank gauge problem fixed. thanks for the help. i think you hit it on the head.
