depends on the make, model and year along with your boating environment and type of use. The Evinrude XD-50 semi-synthetic is a good deal, though.
I want to know the truth of Synthetic Oil & why it's worth or not worth the extra cost / investment?
Never had any problem with regular dino. I take my savings on the oil and add a little seafoam to the mix to stabilize the fuel and hopefully keep my carb from gumming up.
I find oil questions like this are usually a little more vehiment then if you ask the readers "is there really a god" or "should expectent mothers be allowed to abort their babies". You would probably get more agreement with the later questions.
I like to use the synthetic on my old SMALL HP outboards that require 16:1 or 24:1 oil ratios just because I feel like it might protect the friction bearings a little more (I have no proof of this), and because it's cleaner and supposedly more biodegradable than dino oil. However, I personally would not run it in a V4 if I had one because of the high cost. I think regular dino oil has been proven to do the job well. I use mercury quicksilver conventional dino oil for my '98 yamaha 90hp, for example. I don't see any sludge from the lower unit, either.
JMO,
JBJ
i like the blended dinosaur sauce mixed with the high tech stuff - seems like the best of both worlds and not nearly as expensive and the full synthetic and i deffinitely notice less smoke especially on my older motors where i mix 16:1
No, you don't need to put "Ethanol treatment" in your gas unless you are going to store it for a while. Marine StaBil would be the right stuff then.
Neither the oil you use nor the fuel is going to cause or cure idle problems. Doing a link 'n' synch should clear that up.
Outboard engines have been performing very well for many many years without all the snake oil crap the hucksters want you to dump in them, and they can continue to do so with simple, regular TLC.
Yeah the Octane rating of the fuel is not gonna have anything to do with and Ethanol treatment, I'd probably try and use the 87 as most of the experts say it will run best on that, since that's what it was designed for.
Personally I treat my fuel with Star Tron all season long. My boat sits in the water, with usually no less than 60-70 gallons in it, and I'm not gonna take a chance of any phase separation happening for the cost of a $15 bottle of treatment. I don't even consider the BS they say about it keeping carbon lower or anything, I use it strictly to treat the Ethanol, I've seen too many problems. Make sure you have a good fuel/water separator also.
Doing a decarb isn't a bad idea, especially if you don't know the history of the engine, but it's not a miracle in a bottle cure for a rough idle, it's just part of preventative maintenance. As the experts above me mentioned, checking that it's set up correctly will make it run right.
I personally don't trust the Super Tech, it smells like ammonia to me. I'm kind of up in the air as far as dino vs. syn, but JB's post above pretty much makes the most sense. Use what you are comfortable with, some guys swear by different things. I personally use the XD-50, I get it in bulk for $26 a gallon and buy 5 gallons at a time, and it's piece of mind, plus I can use the same oil all season long since I can get it in bulk around the corner from me, it's easy and I know it's decent oil.
