IS this motor flush safe to use?
restornator
I know it would mount below the water pump, and the pump is not self priming. Anyone seen or used this?
Faztbullet
Re: IS this motor flush safe to use?
It mounts above cavatation plate and force waters to pump from a garden hose. It fits 25-40 2 cylinder engines and I do not use any forced water attachment as it does not give a true indication of impeller condition and adds no backpressure to engine.
tashasdaddy
restornator, on what motor????
GatorMike
Ensign
This brings up a question I have always wondered about. On a few occations over the years I have came home from a saltwater trip with a motor that was not running. Does a water hose produce enough pressure to flush an engine without the engine running?
ezeke
If the thermostat(s) don't open, you don't really get much of a flush.
F_R
If the water pump impeller is not rotating (running), the water can't get past it. So, your efforts are in vain.
