is this too much
hillbillyjr
i have a 98 chevrolet c1500 4.3 5-speed 2wd and i have been pulling a 16 foot bass tracker. i am going to buy a new 17 1/2 foot nitro on a single axle trailer with a 90 hp motor this week and i am just wondering if i will have any trouble pulling this boat with my truck. i have to pull it about a 100 miles. do you all think i will be ok. thanks
Bob_VT
Re: is this too much
Check your lights, your hitch and make sure the boat is properly tied down and have fun.
I imagine the hardest part will be you looking in the mirror at your new boat ;)
Yellow Yota
You'll be just fine. Not going to be a rocket, but otherwise a fine package.
hillbillyjr
i will be using a ramp that is only about 2 miles from my house, and it is not very steep at all. do you think that my truck will have a hard time pulling this boat outta the water.
smokeonthewater
as long as you have traction you'll be fine.... some ramps a 2wd can't get itself up but on many you'll be fine.... if you are concerned a buddy with a tow rope can make it mildly embarrassing instead of disastrous
Silvertip
Honorary Supreme Mariner
There are two things that can help tremendously if you do have an issue on slippery ramps. 1) Tires with a grippy tread pattern rather than a standard highway tread. You don't need to buy "Super Swampers" with lugs an inch and a half high. Just a little more open tread pattern. 2) Chances are your truck does not have a locking or limited slip differential. If not, head to your local salvage yard and swap the rear end.
