diver_down
Thread starter- Joined
- Apr 19, 2009
- 64
i finally got "the new boat of my dreams", ....; a 1985 islander 191 with a 1985 johnson 150 (v6).
The thing is this engine seams to me to have quite low compression (80 psi across the board), but i ran the test without opening the carbs fully plus my gauge is off (reads low, i know it from experience - by how much ???).
I ran across another engine that is supposedly in running condition, with good compression , etc, comes with almost everything - a 225 yamaha, the question is "would the boat handle it?" - the dry weight is almost the same - 10 lb difference, ...
Also, in the case that this 225 is too much, my engine seems to have an oil problem - the carb bowls get filled with oil, primer bulb gets mushy, engine stops starting, etc; what would be the best place to start investigating? (after draining the carb bowls it starts right up).
Thanks,
Nick.
P.S. Any info on the 1985 islander 191 would be appreciated.
Thanks,
Nick.
