IT RUNS!! well sorta...
KT64TM
replaced the check valves, diaphragm, and gaskets in my fuel pump today.
hooked up and drove to the ramp to see if she'd run.
she did!!
BUT
wouldnt run unless the idle lever was wide open, even then surged a bit.
would run in gear IF throttle was WO. even then, surged and was only makin' about 3000 rpm. (I know, static run)
she was smokin' (3 gals of old january gas with 3 gals of fresh mixed gas, think its a combo of old gas and too much oil)
Think I need a link and sync.
any suggestions??
KT64TM
Re: IT RUNS!! well sorta...
thats what I figured.
FORGOT to mention, there was a point where she wouldn't start, pulled her out and checked the plugs, oil fouled. thats why I think the fuel mix is to oily and old. Gotta find a place to dump it and get new.
