jacks outdrive
Re: jacks outdrive
Ayuh,... And the Vintage is,..??
Don S
Re: jacks outdrive
Sloooooowly the needed information is pried from his clutches.
Along with the much needed year, a serial number of your engine would also help in determining year of the drive, the year of your boat could be off by a year or 2.
Jack Devin
Re: jacks outdrive
it is a 1985 criscraft 260 scorpion aft cabin 350 eng no numbers on tran or outdrive But i now its a alfa 1
Jack Devin
Re: jacks outdrive
how can i find out witch alfa 1 it is or what shoud be on it this is not the org
Re: jacks outdrive
Ayuh,... an 85 is the Alpha 1 drive... With your V8, it'll be 1.5:1 ratio...
Gen.IIs didn't appear til 91...
Don S
Re: jacks outdrive
One problem with boats, is the engine and drive may not be the same year as the boat. An 85 boat could easily have an 84 or even an 83 engine.
If it's not the original outdrive, but still the original engine and transom shield, it's hard to say for sure what was put on there. An 85 would have been an MR, and the 83 and 84's would have been an R drive, in 86 through 90 they were called Alpha I. Prior to 83, they were called one drives. Basically, they were interchangable if they had the proper gear ratio and splined input shaft.
If you look at the picture below, you will see where the SN and gear ratio are located. If the number is unreadable on the decal, scrape the decal off and look under it, the numbers were also stamped into the casting.
attachment.php
If you have the serial number of the engine, we could at least tell you what year the engine is.
