stricksteve4
- Joined
- Jul 7, 2012
- 6
I have a 1985 Johnson J150TCOH. I have had some work done on it recently, replacing the impeller,the thermostats,the priming bulb and a general checkup. Compression is good per spec. It was bought this summer after only running it on muffs. When I get it up to speed,(4500rpm) it will run well for a few minutes and then just die, like it ran out of fuel. Rpm goes down to zero in about 2-3 seconds. Does not spit or pop, it just dies. Does this engine have some sort of oiling sensor that will cut the engine if it does not get enough oil from the oil injection?? Also after the recent service , it is extremely cold blooded and will not even idle under load. until very warm. It will start easily, and after warming for a few minutes if shifted into forward, it will stall out. It is a struggle to keep it going until it is warmed up totally. The shutting off at speed is my main concern!! Please if anyone has seen this problem before, help!! Could it be the fuel/oil pump??
