johnson 1999 5hp help please
rtpogo11
5hp That Is Leaking Gas Out Of The Side Of The Carb. Please Take A Look At The Picture. I Can Get It To Start Then Idels As Soon As I Get It Turned Up She Dies, Gas Comes Out The Carb Its Seems To Be Flooded. Also When I Try To Start The Motor I Hear A High Pitch Whisting Comming From The Water Discharge Iam Working On Getting The Manual Thanks
Rick.
Re: johnson 1999 5hp help please
Sounds like a stuck needle valve to me. You would need to remove the carb. and clean it up. No idea about the whistle. Is it pumping water once you get it to idle? Rick.
rtpogo11
I REALL Y DONT KNOW WHAT THE NEEDLE VALVE LOOKS LIKE
rtpogo11
She Pumps Water Well But Now Cant Seem To Get It Started Smells Flooded Please Help Thanks Rick
Rick.
http://shop2.evinrude.com/ext/index.aspx?s1=19ff49c4024f2d58ccbad05250399467
Follow the link above and find your motor and then look at the carb. diagram. The needle is attached to the float. For some reason your float and needle aren't shutting off the gas supply the way they are supposed to. Perhaps the float is not floating anymore. Have a good look and the problem might be obvious. You probably won't have a lot of luck starting it because it will be badly flooded. I was surprised when you said you could get it to idle. Rick.
tashasdaddy
time for a carb cleaning and rebuild kit. get the manual if you are mechanically inclined, or pay someone to rebuild the carb. $80-100 per hour.
rtpogo11
i did the carb clean today she is now purring like a kitten thanks to you
just want to thank all of you this site rocks
Rick.
I like stories with happy endings. Did the whistle go away too? Congratulations. Rick.
tashasdaddy
thanks for letting us know. congrats.
rtpogo11
whistle never went away really wierd if i put my finger on the water discharge tube it stops
Mas
I don't know, but I often whistle while I'm taking a leak too...just a habit I guess.
MAS
Rick.
That's the first post ever that made me laugh out loud. Too funny. Rick.
rtpogo11
Re: johnson 78 4hp help please
i have this 4 hp motor johnson i had a oil leak in side the cover found it and fixed it but it made a mess what is the best way to clean up that mess and when i pull the rope the rope does not go all the way back in it stays about 3 or 4 inches out
Rick.
rtpogo11: Your 5HP is running good and we all rejoice. Start a new thread with your new subject. No one likes it when these threads go on for ever and change topics and now you even want to change motors with a new set of problems. You will also get better responses with a new thread. Rick.
