Johnson 30HP water hose question
Jim Hawkins
Still tweaking this motor,
I have a T fitting on the hose that leads to the water indicator pee hole. The hose that comes off the bottom of the T went nowhere but sprayed water so I capped it off.
I don't know what this hose was for. I suspect a PO rigged it for some reason.
If this is original where should it attach?
boobie
Re: Johnson 30HP water hose question
Could have been for a water pressure gauge.
Jim Hawkins
Sure, could have been. But has that T been there from new is what I'm wondering.
boobie
I never heard of the factory installing that T in the line from new.
Jim Hawkins
Alright then.
I'll just replace that hose with 1 piece from motor to peehole.
Thanks
the machinist
I have a suspicion that the PO was a fisherman & installed it to lead to a warm water sink. We see that a lot here in the Pacific NW where steelhead fishermen plumb it into a small sink on the transom. They will then put a shut-off valve at the tank. They use it to warm cold hands & wash off gunk from salmon roe bait.
Jim Hawkins
Sounds logical. By the way, anyone with a 30HP johnson that wants to post a pic of how the water hose is routed would help as I'm pretty sure it didn't go between the spark plugs.
Jim Hawkins
Hey Thanks. A picture really does say a thousand words, give or take a few.
