Johnson 3hp Sea Horse
SeaHorseJW-19M
Hi, this is what I did wrong ( Do not remove the adjusting screw. The adjusting screw does not attach the points to the stator plate and should not be removed. The adjusting screw is the screw that is smaller and farthest from the crankshaft and fits within an elongated slot in the points.) Well i removed the screw,what do I do now? Thanks Alex
F_R
Re: Johnson 3hp Sea Horse
Simply put it back in. Screw it all the way in, then back it out enough to be able to turn it back and forth to set the points (about 1/2 turn)
SeaHorseJW-19M
Well I tightend the screw and backed it off 1/2 turn what next.Do i gap the points now B4 I tighten the screws,the screw that is backed off 1/2 turn is a screw that its head is lop sided so it need s to be positioned at an exact place.I installed new points but dont know if its properly done ,where does the springs go ,do I use the little copper tabs to hold it to the point body.I need a pic or diagram if available thanks guys Alex
SeaHorseJW-19M
Thanks Admiral, well i have that site but it doesnt help me ,I need a more micro pic of how every thing it set up.thought someone would have a diagram or something on this site looks like i will have to visit the library to find a manual.The points have a metal tab that acts as a spring and it needs to be set up to act as a spring,so it is held in place some where ,I have it against a post but the kit has a brass or copper clip that will clip it to the point ,so i'm not sure if thats how its to be done ,boy I just started to do a tune up and a little detail like this has caused me to spend hrs trying to figure out.Maybe I'll be boating in 2020 or something lol.Even the screw that I took out is causing me grief.Maybe I'm not meant to be a skipper.
HighTrim
It shows it in the pics in the link that I posted.
SeaHorseJW-19M
Thanks ,I see it now ,I increased the size of the page THANKS
SeaHorseJW-19M
Well I did the tune up to the best of my ability,I'm at the stage to check for spark ,BUT nothing ,am I doing something wrong I wonder.It says in article to test the coil but I took a chance and hoped it was ok.Where do I go from here should I put tank back on and see if it will run.The coil points and condensor brand new.I tried turning the engine like article states and ground old plugs but I dont see and spark Thanks. Oh,forgot to mention I set the points by site, can't find my feeler guage,so I just set so it opens and closes a little bit would that affect spark.Or produce no spark
HighTrim
You cannot set the points by sight. You will never get it to idle right, if even start. The points need to open exactly 180 degrees apart, hard enough to accomplish with a feeler gauge and not a timing fixture, let alone with nothing.
Post pics of what you are dealing with. Maybe we can spot other issues.
SeaHorseJW-19M
DSC03943.jpgDSC03945.jpgDSC03944.jpgHope this helps ,another thing is does the flywheel have to be torqued in ordser to get spark thanks
tx1961whaler
Are each set of the points set to open at 0.020" exactly at the high point of the cam? It looks like in the 3rd pic that they are open and the cam is not all of the way around, but pics can be deceiving...
No, the flywheel does not have to be torqued down all of the way to test.
SeaHorseJW-19M
no I only set it by site ,they weren't set with a guage,I can't seem to locate my guage,I was just setting it without a guage to just chk for spark didn't think it had to be exact just to see if there's spark thanks
kfa4303
Banned
Yeah they need to be set by a gauge and just as importantly they need to have the same gap, even if it is slightly off from the .020" factory spec. Be sure the points are perfectly clean too. If they're brand new you're ok.Otherwise you way want/need to sand down the surface of the points with some very fine sand paper to remove any oxidation that might have accumulated. There's really no way to "eye ball it" effectively. Once set properly, you should be able set the flywheel on top and spin it a few times by hands with the spark plugs removed to check for spark. Here are some handy links.
http://www.outboard-boat-motor-repa...on 3 HP 1952-1967 Ignition System Tune-up.htm
http://www.youtube.com/watch?v=4GHWXwC_lbE
SeaHorseJW-19M
Just an update, I broke down and bought a new feeler guage,set the points and I am now getting spark:) I was on vacation so haven't done much else. I need to put tank back on and see if she runs.By the way I live in Richmond Hill ,ontario ,Admiral ,bye for now
kfa4303
Banned
Glad you got some spark SeaHorse! You're gettin' there. You'll be vroom-vrooming in no time.
SeaHorseJW-19M
well I put the tank back on and attached fuel and it starts for a few secs and dies so far, any tips on starting it,where should the slow speed needle be ,and the choke on or off .I turned the slow speed needle all the way in and backed off a few turns,it has a lean and rich setting not sure where yet to set and how many turns to back off the slow speed needle .Thanks Alex
kfa4303
Banned
SeaHorseJW-19M
Thanks Captain, A BIG update ,put it in a tank and got her going ,ran her for a little ,it was pushing water out of the tub I had felt the engine it was pretty hot so stopped ,does the engine body normally so get hot, not sure if its more than normal ,not sure where to go from here have to check the impeller i suppose ,the lower unit .But she starts so thats a good start thanks for help guys ship ahoy:)
