Re: Johnson 40 Electric Seahorse
So, I installed the ignition switch and things are working well. When I purchased the boat, the guy I bought it from fired up the motor (using muffs) and gave them to me. What kinds of things would you all recommend I do/check to make sure the motor is in good running condition? I am fairly comfortable tinkering.
What mixture goes in the tank? What would you recommend for a motor this old? I thought I read that the mixture ratios were changed??
Thanks. Any advice will help. I know there is no guarantee on these things, but I want to make sure I catch any major issues before I put her in the water. What kinds of things should I check for?
