Johnson 40 hp motor id
lildoggy
My first boat. Just bought it. It has a Johnson 40 HP motor<br />Model # - 40FL-72E (F could be an E)<br />Serial # - J3626597<br />Any help with the id is appreciated in advance. Now what would be the next step for me. Manual?<br />Gas ratio to put in new gas before trying it out?<br />Lube check where? Also doesn't seem to have the vents I have used before for water cups to run it at home. Is it not water cooled?<br />As you can tell, this will be first of many questions, thank god this site is here.<br />Lildoggy
Paul Moir
Re: Johnson 40 hp motor id
Welcome to Iboats!<br />That's a 40EL-72E, 40hp Electric shift Longshaft (EDIT: That should be Electric START) 1972 outboard.<br />From back when model numbers made sense. :) <br /><br />Gas ratio is 50:1 87 octane gas to TC-W3 outboard oil. It's water cooled. Water goes in through the fin just behind the propeller (screened part), and you need a flusher that fits it rather than the cups. Tempo 917TFA fits it, and Iboats carries it. Otherwise you can test it in a barrel of water, filled up so the seam between the lower unit and midsection is covered. Water should gush out the large hole in the back of the mid-section a few seconds after the engine starts.<br />Lower unit lube is 90 weight outboard gearcase oil (OMC/BRP 'HiVis' at the Johnson dealer). Do NOT remove the phillips screw from the side of the fin, only the slotted one.<br />Can't beat the factory manuals - they're well worth the extra $. You can get them here:<br />TheOutboardWizard<br />Mastertech<br />Marine Engine<br />Ken Cook<br />Here's some ebay deals:<br /> Auction 1<br /> Auction 2
lildoggy
Dang Capt. Paul<br />You are my friend!<br />Can't believe how much help you've given me so fast.<br />Heading for the manuals and will be back.<br />Thanks again.<br />Lildoggy
