Maverick49
- Joined
- Jun 4, 2007
- 28
My 40 hp johnson was running fine, started up fine, had no problems with the electrical what so ever, but my warning horn was unplugged cause it buzzed constantly, I suspected my vro was plugged but that was not the case, my vro works fine, so I checked my temperature sensor like my OMC manual said to do and it checked out ok also. So I was told that the warning horn could be defective, so this morning I ran the motor and while it was running, I hooked the wire up that was unplugged to the horn and it kinda buzzed a bit then quit, but when I touched it to the side of the boat it buzzed and only when I was touching it like it was grounding out on the aluminum? does this make sense? It made me think that the horn is defective so I unplugged both wires and plugged them back in again but to the opposite terminals and I couldn't get it to buzz again, it just wouldn't buzz for nothing. But then my motor wouldn't start, when I turn on the key the voltage meter on the dash does nothing. I tested my solenoid like the OMC manual says but my voltage meter was acting weird so I don't know if I got an accurate test, I checked and double checked all of my fuses and all were good, But I can cross the terminals on the solenoid and it will start. I'm lost can anyone help me?
