Re: Johnson 50 HP - Tilt - Please Help - New baby on the way so I can't buy a new one
I pulled it all apart this weekend the motor is shot; completely rusted. The inside of the reservoir was filthy so I cleaned it up. Here are some before and after pics of what it looked like after I removed the tilt motor
http://picasaweb.google.com/willfisher929/JohnsonTilt# Apparently, the unit went out and the original owner ran it for some time in both salt and fresh water with the plug removed. He did disconnect the wires from the tilt motor to the engine.
With the tilt motor removed, as in the pics, I added some hydraulic fluid and manually lifted and lowered the motor a couple of times. When I raised the motor (extended the hydraulic arm), it sucked up the fluid and then when I lowered it the reservoir filled back up with hydraulic fluid and a little bit of that goo that was in there (you can see it in the pics). I had to reinsert the pin to reattach it to the boat as I can't extend and retract the hydraulic by hand. The hydraulic isn't stuck or anything and seems to be fine.
I just need to get a new motor, install it, fill the reservoir up with fluid and reconnect the wires, right? Two of the plugs are missing, which you should be able to see in the pics.
Can y'all think of anything I'm missing? I don't want to go buy a new tilt motor and plugs and then have it still not work.
There are some pics from the OMC Parts catalog showing everything in that Picassa album
And below is the list of parts to which the numbers in the diagram correspond.
If anyone could take a look and let me, I would be forever grateful.
Thanks guys!
Ref # Part # Parts Description Qty SA Note Footnote
1 0438135
Add to pick list HYDRAULIC LIFT ASSY. 1 4
2 0160084
Add to pick list *BALL, Valve seat 1 2
3 0302290
Add to pick list *WASHER, Screw, motor to manifold 4 2
4 0320780
Add to pick list *SCREW, Tilt & trim motor 4 3
5 0911522
Add to pick list *O-RING, Oil pump to manifold 2 5 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
6 0321942
Add to pick list *SCREW, Oil pump to manifold, short 1 6
6 0335646
Add to pick list *SCREW, Oil pump to manifold, long 1 7
7 0333496
Add to pick list *SPRING, Housing to poppet 2 4
8 0436606
Add to pick list *VALVE HSG. ASSY., Manual release 1 4
9 0335143
Add to pick list **O-RING, Release valve 1 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
10 0339849
11 0335132
Add to pick list *O-RING, Manifold to housing 2 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
12 0335133
Add to pick list *O-RING, Valve seat 2 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
13 0335134
Add to pick list *POPPET, Check valve 2 4
14 0335136
Add to pick list *SPOOL, Shuttle 1 5
15 0335137
Add to pick list *SEAT, Poppet valve 2 4
16 0335138
Add to pick list *PLUG, Retainer 2 4
17 0335140
Add to pick list *PLUG, Retainer 1 5
18 0335141
Add to pick list *DRIVE COUPLING 1 4
19 0335142
Add to pick list *WASHER, Piston to tilt rod 1 5
20 0435566
Add to pick list *CAP ASSY. 1 4
21 0335148
Add to pick list **SEAL, Tilt rod 1 3 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
22 0335149
Add to pick list **O-RING, End cap 1 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
23 0335154
Add to pick list **WIPER 1 3 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
24 0335155
Add to pick list **RING, Backup 1 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
25 0335156
Add to pick list *GUIDE, Ball 1 5
26 0306311
Add to pick list *LOCK WASHER, Pump to manifold 3 4
27 0335130
Add to pick list *PLUG, Manifold 2 5
28 0335159
Add to pick list *NUT, Tilt rod 1 5
29 0335171
Add to pick list *VALVE SEAT 1 5
30 0335657
Add to pick list *FILL PLUG 1 4
31 0335658
Add to pick list *O-RING, Fill plug 1 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
32 0914069
Add to pick list *RETAINING RING, Manual release 1 4
33 0335660
Add to pick list *O-RING, Valve seat 1 5 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
34 0335661
Add to pick list *SEAL, Manifold - 1 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
35 0335129
Add to pick list *O-RING, Plug 1 5 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
36 0335663
Add to pick list *FILTER, Oil pump 1 5
37 0389836
Add to pick list *OIL PUMP ASSY. 1 4
38 0433225
Add to pick list *ROD & EYE ASSY. 1 4
39 0437801
Add to pick list *MOTOR & CABLE ASSY. 1 4
40 0513667
Add to pick list **TERMINAL 2 3
41 0335152
Add to pick list *WASHER, Piston 1 4
42 0435899
Add to pick list *MANIFOLD ASSY. 1 5
43 0340174
Add to pick list *FILTER, Manual relief 1 6
44 0433814
Add to pick list *PISTON ASSY. 1 5
45 0335143
Add to pick list **O-RING, Piston 1 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
46 0335145
Add to pick list **RING, Quad 1 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
47 0335144
Add to pick list **RING, Backup 2 4 Contents of O-ring & Seal Kit . Contents of O-ring & Seal Kit .
48 0335153
Add to pick list *SPRING, Relief valve 1 4
49 0582499
Add to pick list *BONDING STRAP 1 6
50 0335131
Add to pick list *FILTER, Reservoir 1 5
51 0912298
Add to pick list *BALL, Relief valve 1 5
52 0332434
Add to pick list BUSHING, Manifold to rod 2 2
53 0512259
Add to pick list SLEEVE, Cable 1 5
54 0513665
Add to pick list SEAL, Connector 1 3
55 0332436
Add to pick list BUSHING, Tilt cylinder to bracket 2 2
56 0435567
Add to pick list O-RING & SEAL KIT 1 3
57 0513664
Add to pick list CONNECTOR, Tilt motor 1 4
58 0911729
Add to pick list *O-RING, Connector 1 4
