Johnson 60 twin abruptly stopped peeing.
FZ1
Hi Gents, I've been reading the forums for a few weeks now and you guys have a wealth of knowledge, hope you might have some experience with what just happened to me.
The engine: 81 J60ELCIA: new to me about 3 weeks ago. No history known. Run on the muffs like a champ, even had it in a barrel briefly and would go into gear(s) without barely changing from no load speed. Every time it was run in the driveway it had a real good strong (shooting 5 ft) pee stream, and the stream would get warm after a minute or so of running at 75F ambient, not sure of garden hose water temperature. Impeller seemed to be working ok so I decided to just change the gear oil, and go put the boat in the water for the first/last time before winter.
I opened the gearcase drain and vent (non electric ) and got clear water for a second before milky gear oil. The volume of fluid left in the drain pan was very little after letting drain for 2 hours. The neoprene washers on the drain and vent screws were obviously mangled and ruined by the previous idiot, so new idiot changed them and filled gearcase with around 30oz of fresh 90wt (Shell Nautilus) I also painted the lower for looks and to help to search for oil leaks in the future. No I did not paint over the water intake grates, or any drain holes ;)
Next driveway run........ no pee stream! shut down, adjust muffs, try again, nothing! Tried 3 times before I gave up. Engine ran about 60 seconds, so no harm done but....Any ideas why new gear oil and cosmetic paint makes your impeller decide to commit suicide? Here's hoping when I do eventually drop the lower this winter, that I find all the impeller parts close to where they were originally and not jammed up in the powerheads water jackets :mad:
Benny1963
Re: Johnson 60 twin abruptly stopped peeing.
not suicide just bad luck change the pump out before ya burn it up flush it while lower is off
tashasdaddy
they just up an quit, when they want to. i've started mine on muffs, before leaving for the ramp, 15 minutes later in the water no tale tell stream.
FZ1
The damndest thing..... I remembered that i had the muff with the hose connection on the opposite side when it wasn't peeing, so i decided to try switching. Guess what? It works now. Am I missing something? I know that both sides of the lower have water pickups,... its obvious. Could it be just the length of time the engine sat? I feel kinda dumb. :redface:
tommylinda
i have a 50hp johnson and for some reason mine stopped too. i just bought the motor last week, and the guy i bought it from is trustworthy. he replaced the impellor and said that last monday he hooked up the muffs and tested it. it worked after he found that dirt daubers had nested in the out hose, and cleared it out. i bought it, got it home and hooked back up and now no water stream. is it supposed to shoot water right away or is it controlled by a thermostat that cools motor after a certain temp? he said it should pump right away or at least it did for him. only thing that happened between there and here was the thing that locked the motor in the up position for transport broke and i dragged the motor for about a 1/4 mile before i could safely pull off the road. only apparent damage looks to be the bottom has been ground down a bit. could something internal be damaged that could cause water not to be pumped thru motor? any help would be greatly appreciated. thanx
