Johnson 6hp won't run slow
jddens
Picked up a used dinghy today and it came with a 6hp Johnson. motor runs good a rpm but won't idle or run slow. My first thought is the low speed circuit in the carb. I'm thinking a rebuild kit but thought I'd check with the experts first.......thoughts? Thanks in advance............John
Monte1961
Re: Johnson 6hp won't run slow
I would. what year and model are we working on? post back.
Daviet
It does sound like a carb problem, but I would check the spark and compression also. Either one of the above could cause the problem.
jddens
Not sure of the year....model number is 6RL79E.....maybe 1979?? Ser number is J5106337.
I'll check compression but it runs real good at RPM so I think it will be good..........THANKS!!
Monte1961
You are correct! 1979 Johnson 6RL79E 6hp Outboard Motor!
Daviet
Question is, is it running on both cylinders?
samo_ott
If it runs well at speed then it's most likely a dirty low speed circuit in the carb.
jddens
yes, running on both cyls...........i'll order a carb kit and go from there.....thanks for the rapid responses............John
jddens
Problem solved! Removed the carb, disassembled cleaned everything, blew out all passages, re-assembled and re-installed.......runs perfect!!!
