Hey all
'89 tracker tournament v17 pro with an 88 johnson spl 2 cyc, 4 cyl engine
I am trying to figure out what is going on with my engine. I have owned this boat for about 6 months now. Since then it is becoming harder and harder to start. When i first got the boat, starting it was temperamental (started within 1 minute) and it didnt like to idle very well. So i mixed up a full bottle of seafoam into 1 gal of fuel/oil and ran it dry. The boat idles much better now but on rare occasions, it might die when advancing the throttle just a bit from idle to high idle (but only in the water, doing this in the driveway doesnt affect it like in the water). Also of note, all the plugs were black and wet upon pulling them after the engine warmed up. I am also inclined to believe there is some flooding going on due to the strong fuel smell while trying to start it. I am also noticing that the fuel line, where it plugs into the plug of the engine is loose and sprays a little while priming.
Today it took me about 15 minutes of grinding to start it. It would hit immediately but never catch and run. So i gave it a break for 5 minutes, hit the key and it fired right up. I do follow A start up procedure that i found here on these forums. Prime it, push in the key for 10 sec and start grinding with key still pressed in. Anyway.... i let it run for about 15 minutes and began the compression test. All cylinders were tween 75 and 80 psi. I came back in and made a few calls to marine shops over the low numbers and watched a few videos. OOPS! I forgot to advance the throttle to full. By this time it had cooled off for about 15 minutes or so. I did the test again and here are the results.
Facing rear of boat Left side first and then right. top to bottom.
85 86
80 89
Keep in mind that the tester is an amazon special 8milelake about $18. I am working on comparing the results with my neighbors tester (if he has one) maybe tomorrow. In the mean time, i sprayed the cylinders full of seafoam and put the plugs back in.
But how does the engine run? I always start the engine in the driveway with earmuffs before taking it to the launch because of the hard starting. Once i launch it, i hit the key tween 3 and 5 times and it fires up and idles good. It runs like a scalded dog and has plenty of power, no misses or anything. I can shut it off and fish for an hour or 2 and hit the key and it fires right back up first try. In other words.... once i get it started...it acts normally the rest of the day on the water.
I know i prolly need to also rebuild the carbs but i have been having a hard time finding the right kit. I get a part number and start comparing prices when i notice the photos (gaskets in the kit) are not the same from one kit to another. The engines serial/model tag is long gone. I made some calls and pretty much hear the same crap about our books dont go back that far ect... So i asked for help here on the forums and no one was either willing or could help. So ill save this as a last resort but i suspect if it is flooding, thats a carb issue.
Any insight?
thanks in advance!
85 86
80 89
Any insight?
thanks in advance!
