Johnson 9.9 idle problems
Country Joe
Have a 2000 Johnson 9.9 that the dirt dabbers built a nest in the carburetor, tore engine down cleaned everything, new car kit, now engine will run fine but will not idle. Any suggestions?
boobie
Check your compression. If that's okay, do your carb again.
Country Joe
Compression in both cylinders is 110. Will try soaking and rebuild. Thanks for the replies!
