Re: Johnson pros i need help
I think I talked to you at the Chula Vista Launch Ramp. If not disregard this. You are failing to mention that you replaced the ignition switch. Disconnect the black and yellow wire from the switch since its just hanging there, and see if it fires up. If you touched the black and yellow wire to the red and purple wire, AT ANY TIME WHILE THE WIRES WERE HOT (you possibly would have seen a spark if you did), it is possible you fried the powerpack. Also make sure that the terminal locations are correct. The black and yellow gets its own terminal, I believe terminal M. It is right next to the red and purple wire terminal, which is B. It goes like this: clockwise, terminal "A" Purple, terminal "M" Black ( next to terminal "A". there are 2 "M" terminals) terminal "B" red/purple, other terminal "M" black/yellow, terminal "S" red/yellow, terminal "C" purple/white. hope this helps...
