FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1988 Johnson 40hp w/tilt and trim. I replaced the pump 2 years ago and have not been able to get the tilt to stay up. It will go up fine, but will creep back down. Has anyone had this problem, and what can I do to fix it?
The first thing that you should check is that your manual release screw is closed and tight and the o ring is not leaking. There may be a leaking cylinder piston or sleeve o ring. It may also be an internal valve. Can you see any signs of fluid loss/leaking? Have you checked the level of the fluid then bled the system to ensure it is not just low?
rebuilt both cylinders and wont go up all the way
tryed bleeding system getting better,what is the correct
way to bleed the system.1988 johnson 40hp? nothing in
the book.
