jump time?
picker523
I took the 87 3.0 mercruiser out after replacing fuel pump ..;. adjusted shifting so it would shift properly .... set carb... and noticed it popping at high speed. So I got my buddy to drive while I PLAyed with the timing , but before it could get up to full speed it started popping really bad as though it were suddenly 180 degrees out of time .I NEVER loosed the distributor enough for it to allow it to jump time . Any suggestions?
Haut Medoc
Re: jump time?
Water in your fuel.....
Have you changed your water separating fuel filter, ISO?....:confused:
picker523
Re: jump time?
I just put a new fuel pump on it. I left the switch on last night and some one said it could have messed up the coil.
Haut Medoc
Re: jump time?
A new fuel pump will pump water too, if it is present......;)
A bad coil might react like that.....
Do you have a water separating fuel filter & if so have you replaced it?.....:confused:
bruceb58
Re: jump time?
Are you setting the timing with a timing light?
picker523
Re: jump time?
It being a new fuel pump I did'nt even check the filter. WHAT do I look for? I thought it strange how it started all of the sudden and not gradually. wouldn't water come in slowly to the fuel supply?
Haut Medoc
Re: jump time?
It will look like an oil filter.....
If you have one, replace it.....;)
It does not come standard on a 3.0....
It does not take alot of water in the gas to make an engine run like carp!....:)
Re: jump time?
Ayuh,........
It sure sounds like Fuel Starvation to Me..........
Maybe it's something besides the Fuel Pump,...... But it's Starving..........
Reel Poor
Re: jump time?
AND.....The ONLY way to set the timing is with a timing light.
bruceb58
Re: jump time?
Not really sure how to find the timing mark but I do have a timing light.
Time it with your timing light to undo what you have already done. This will save your motor in case you have advanced the timing too far.
picker523
Re: jump time?
well I found out what happened. I pulled off the valve cover and found a couple of bent push rods. I don't know if I got it too far out of time (will that cause it?) or if I needed to re-adjust the valves . I had the heads reworked about 6 months ago and don't know if I set them right.
180shabah
Re: jump time?
If you don't know if you set the valves right, then you didn't. You really need to get your self a manual for this engine before you completely destroy it.
Limited-Time
Re: jump time?
Correctly and incorrectly set timing on a 3.0
is the difference between a good running engine, and the need for major engine repair.
ziggy
Re: jump time?
played with it? i don't know what the specs on yer engine are. but there are specs. playin with it won't get it. find out the facts in a oem service manual and set it up.....
picker523
Re: jump time?
I have a timing light and WILL make sure I've got it right next time. Thanks for help.
wncrjb
Re: jump time?
well I found out what happened. I pulled off the valve cover and found a couple of bent push rods. I don't know if I got it too far out of time (will that cause it?) or if I needed to re-adjust the valves . right.
If you can see one or two bent push rods.... you might want to replace them all, not just the ones that LOOK bent, it's cheap insurance.
wncrjb
