noob_boater
Thread starter- Joined
- Jun 23, 2012
- 29
The previous owner got it running in just one pull 2 times. Awesome.. I'm new to boat outboards so got a few questions. I know it runs good, but can't take it on water yet before fine tuning this thing. I got a list of parts i need to replaced according to the many threads on this motor.
1. Spark plug Rj-12YC/14YC.. what's the difference? hotter?
2. 90W marine gear oil. Do i drain the old oil like car oil change? i assume that would be the case...
3. Carb kit. Will this fix the rough idle?
4. 24:1 fuel/oil mix? Do i use the the 2 cycle TCW-3 oil or some special oil?
5. replace fuel lines......... anything else i should do?
***Will this outboard require a fuel primer bulb? I don't see one and forgot to ask the previous owner how i should start this thing if all fuel has been emptied from the carb bowl...
