Re: Just clearing the air
Originally posted by Scott89racin:<br /> I don't know how long you've worked on boats as a pro BONDO but I've read many things that are different. <br />For example High Silica Blocks which don't rust thru, different head gaskets which take the salt better, brass core plugs, special coatings on exh valves which help with moisture from water cooled manifolds. Also cams are differnt. When was the last time you ran your truck at W.O.T(wide open throttle) for a few hours at a stretch. Also stock internals are weaker as well as cranks are differnt.(example bolt pattern on a two piece rear main are differnt from one piece in marine applications) Some marine engines are internaly balanced while cars are externaly balanced, also crankshaft offset is different from one piece rear main vs two. Marine heads usualy have better flow or different shaped ports all together(ex 3.0 is NOT a 2.5 iron duke, parts are not even close to same and the ports are on same side, unlike car engine)
I Don't work on Boats Professionally,.............<br /><br />I Am,+ have been a Mechanic for well over 35 Years,.......<br />I Know enough to Look Passed the Marketing Hype,+ See the Parts used to Build the Engines in Question................<br /><br />Reading this post Quoted,.........<br />You Don't have a Clue as to Why different Parts have been used When, Or For Which applications on What SBCs..............<br /><br />Just a couple points,.......<br />
Wrong,...... That's High Nickle blocks that were designed for Hi-Pro App.s, because of the High Strength,+ Were Adapted to Marine.........<br />And,........ Are Still NOT used in Standard Production Marine Engines............... <br />
As stated in the referenced thread,..... Steel Shim Gaskets are nearly a thing of the Past,.........<br />Composite Gaskets of Today,.. Don't Rust....... No Difference......<br />
OK,........ That's 1 Minor Difference......<br />
That's a New Fantasy..........There ARE Many Different Valves that Can be used in Hi-Pro App.s,... <br />But,..... Standard Production Marine engines Are,+ Have been using Standard Production Truck Valves..........<br />
As stated in the Other thread,.........SLIGHTLY Different..........<br />A Boat will Run Forever with a TRUCK Cam,+ You'll Never FEEL the Difference........... <br />
Wrong Again,............<br />Same Cranks,.........<br />The Difference between the 1 pc.,+ 2 pc. Rear Main Seals is about the
Vintage of the engine in Question..........<br />All SBCs were 2 pc. seals up to 1986/87.........<br />It's got NOTHING to do with wether it's Marine or Automotive.................<br />BTW,..... ALL SBCs have been 1 pc. rear main seals Ever Since....... <br />
Wrong Again,..........<br />Only the 400cid SBC is Externally Balanced,..... Period.........<br />ALL the Other SBCs have been Internally Balanced,........ Since 1955............<br />Crankshaft Offset is Different,..?????..... How So.......<br />Crankshaft Offset determines the Stroke of the engine,.... Which determines the Displacement of the engine,.........<br />Which has NOTHING to do with wether it's Automotive, or Marine.............<br />
Wrong Again,.................<br />The Standard Production Marine Motor uses the Exact Same Heads as the Standard Production Truck engines that are being built At That Time...........<br />
ex 3.0 is NOT a 2.5 iron duke, parts are not even close to same and the ports are on same side, unlike car engine) <br />
This is a Totally Different Discussion,.........<br />The 3.0l engines are a Marine/Industrial Only motor,..........<br />It's NEVER been in an Automotive Application,............ Ever...........
<br /><br />Next,.............................................................................
