Just clearing the air
DukesFin
Re: Just clearing the air
I just want to know if I can pull the motor out of my '69 VW Beetle and run my 22' Grady!<br /><br /> :D <br /><br />What a great thread! Most amusement I've had all day!
mkast
If you argue with a Beagle, who wins?
Northern Eclipse
Ya Dukesfin go for it, its an air cooled engine so you'll have to put on the deck...just think no more winterizing
bomar76
Remeber the idiot who posted that thread a while back about supposedly putting a Honda Goldwing enigne in his boat?<br /><br />I guess the average age of these posters is around 12.
FreeBeeTony
I'm behind Bondo and Don all the way here.<br /><br />Their knowledge and willingness to help is above question.<br /><br />It was kinda fun to read though.........was like trying to tell my 20 year old son something......you can't.....lol......
Haut Medoc
FBT, I don't think I have seen a picture of your new ride.....Sweet!....JK
FreeBeeTony
Thanks JK............I like it too......<br /><br />Hope it runs as good as it looks next year!!!
Darkhorse1201
I for one (being the thrifty person that I am) would much rather pay alittle for a truck engine versus the HUGE money they get for a "marine" engine. Hecj, go on ebay and look for engines - I could get a replacement block for my 4.3 for under $200.00!<br />Just my 3 cents worth (adjusted for inflation)<br />:)
KaGee
Originally posted by swsidlo:<br /> Just my 3 cents worth (adjusted for inflation)<br />:)
Ya short changed yourself... we all know that the COL in Massachusets is very high... so you are entitled to at least .04. :D
whywhyzed
Banned
Wow... why did I come into this thread... That kid should take an engine apart...<br />4 posts and gone... hope he's still reading.. <br />You don't learn anything typing or talking, but reading and listening with the proper filters and sensability... priceless
tashasdaddy
you are 100% right hystat. i've only be on 2 weeks and learned so much. got my telephone book size manual yesterday. i've been good with cars, but the is almost totally new. thanks for all the info you guys put out. bob
Originally posted by Scott89racin;<br />Topic: Just clearing the air <br /> A friend of mine thinks that a bone stock engine out of a truck will work in his boat. I told him that is true mechanically, but cams,gaskets, hardware ect are different. He won't listen. He also thinks reverse rotation drives are backwards running engines. :confused: Anyone got a Merc link to help me out and show him the evil of him ways.
Ayuh,..... It's Too Bad..........<br /><br />I Kinda Expected the Reaction,.............<br /><br />Scott came to iboats Looking for Proof that He's Right,........<br />In an On-going Arguement with His Buddy..................<br /><br />Instead,...........<br />He Found the Truth,........<br />And,......<br />Unfortunately,..... He's Still in Denial,......... :rolleyes:
kfraser
OK Bondo,<br /><br />This one has had me scratching my head for several months now. Just what exactly does "AYUH" mean???
Haut Medoc
"K' Pretty sure it means "Yup" in New England Speak....North N.Y. that is......I'm sure he will clarify though....Did you get all of the bugs worked out of the 888? How's the Alaska trip coming along? :) ....JK
rodbolt
the valve guide thing was funny though. I cant remember any american production heads that actually run removable valve guides. most all I ever cut the valves and knureled the guides on were plain cast iron, as in just a hole drilled in the head.<br /> the advent of the center valve cover bolts was the same year as the one piece rear main, about 85. by 87 all the 5.7 motors had eliminated fuel pump mount as the auto industry had gone to FI. but as merc and others purchase units in large quantities there were a few years more of external mechanical pumps in boats. <br /> and while the 400 was externally balanced and the rest of the SBC line was internally,not sure about the 6.0L merc, there were about 10 different harmonic balancers as the cranks were balanced differently. the 5.0 and 5.7 had the same forging numbers and same stroke and journal dia's the balance was different and would vibrate if the correct balancer was not used.<br /> its been a bit since I did the hot rod thing so I cant quote part numbers anymore. <br /> almost every SBC,7.4 and 8.2 and 8.1 motor I have taken apart had steel shim head gaskets as production use. if you wish they are availible for reinstall but I dont recconed the field tech to use them as surface flatness of the head and deck is rather critical and hard to achieve without surfacing.<br /> as far as the water pumps go merc buys them from GM, in fact GM changed the seals a few years back and cost merc a bundle as the new seals were not compatible with raw water cooling and the pumps dropped like flies.<br /> as far as the heads I have never seen a difference between a production auto/truck head and marine in the same HP class motor. in fact a few of the HP auto heads actually flow better. myself i have never seen a reverse rotation motor with an outdrive from any make but it would not suprise me.
Originally posted by kfraser:<br /> OK Bondo,<br />This one has had me scratching my head for several months now. Just what exactly does "AYUH" mean??? Originally posted by Medoc:<br /> "K' Pretty sure it means "Yup" in New England Speak....North N.Y. that is......I'm sure he will clarify though....Did you get all of the bugs worked out of the 888? How's the Alaska trip coming along? :) ....JK
Well,..........You're Pretty Close,.........<br />pronounced,....Aye-yuh......<br /><br />It does mean, Yes,.. Yup,... Correct,... Afirmitive........<br /><br />It's also Much more localized than New England,....<br />Definitely Doesn't have Anything to do with Northern Ny,.... Other than I'm a Native Maineiac, who happened to settle Here......... ;) <br /><br />It's from the "DownEast" dialect,.........Please don't confuse it with the Funny Talking Bleeding Heart Liberals of Massachusetts,..!!!... :D <br /><br />DownEast is a Small area of the Maine Coast,.... though the boundaries are Not well defined,... Generally,.. DownEast Maine starts about where the Penobscot River(the creek I was born,+ raised on,.. Grandparents Bond lived on it's shores) flows into Penobscot Bay, at the Coast,.... Up the coast easterly to Eastport Maine,... The most Easterly point of Our Country.....And,.... Encompasses about 30/40 miles Inland,+ All the Many Islands Off that Coast............<br /><br />Basicly,.... The dialect can be interpreted by Removing "R"s from All the words,+ inserting an "ah" in place of the "R"s.........<br /><br />Sooo,....... Ayuh,... It's My heritage,+ where the Best, Tastiest Lobsters grow.... Not where I live Now........... :D ;)
kfraser
Bondo,<br /><br />Looks like we grew up in the same neck of the woods. Right at the mouth of the penobscot river for me in Stockton Springs. Was just back there week before last. Makes sense now on the "AYUH"...just hadn't seen it used in print. I'm thinking you were around Bucksport??? <br /><br />KJ,<br /><br />The old 888 is resting comfortably in my garage waiting my lazy butt to get the stringers and floor finished in the Commander. Help is supposed to be on the way, but I might have gotten short changed on my "you work for me for a week" and "I'll help get your boat floor in"...<br /><br />Check out my post in the Restoration section..
kfraser
JK,<br /><br />Almost forgot. I decided to put the Alaska trip off until the engine goes back in the boat. That way whan I ask a question in "Person", I can see how friendly the reply will be...lol
