Hi Everyone,
Just got the marine service inspection report on a boat I am considering.
Its a 1993 Sunbird with a 115 Evinrude.
Compression - 150 - 145 - 145 - 145
Lower Unit: OK, holds pressure
Spark: OK
Hard Start - Needs carbs rebuilt
Needs impeller - stream weak.
Steering stiff: Suggests first cleaning/greasing the steering rods/connection to the motor. Tech said this usually takes care of the tight steering.
Other odds/ends I can handle myself.
Here is the estimate:
Carbs - about 400.00
Steering - Labor only, about 150.00
Water Pump - about 125.00
Is this reasonable? I would like to learn to do this myself, however I just don't have the time for it right now. In the future, I would take it on.
The boat is 3000.00, not sure if he will negotiate.
Thanks for any advice.
MS
Rebuild Carbs -
Spark: OK
MS
Rebuild Carbs -
