Just one of many ss 160 redo,s.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Light installed on boat.
Really nice progress!!! I like that light. I will have to look at adding one like that too when I finally get to that stage. Someday...... LOL
Do you know or does the specs on the unit tell you how many amps it uses? Couldn't find anything online.
As for the other boat, when you are done YOURS WILL LOOKS BETTER!!!!!! That guy just dropped a wad of cash. You put love and time for yours :love:
82rude
Halogen light for car uses 55 watts generally equivilent led light uses 3 watts.Bulldog acc has a nice little write up on this.
SHSU
Thanks, I will have to store that in the back of my head for future reference. Trying to make sure I have enough power for an entire day of boating and running of fishing equipment.
82rude
Thats the beauty of led ,very low power requirements.My etec has a very powerful alt .81 amps total.
SHSU
The beauty of a newer unit, charging power.
Mine would consist of me with a hand crank to create power....:D
82rude
Repainted front and plugged 12 holes with permatex cold weld epoxy.Put a bondo stell mesh backing on first underneath.
82rude
HERES the switch for the light bar on the right hand side of steering wheel right above the system check guage.
SHSU
That is some nice work. How big a piece of mesh did you use behind the holes?
82rude
Just enough to cover the hole and give the epoxy something to grab onto.The patch is just like steel,you can drill,tap, jump on, whatever.Time to splash her and see how the fasco really did for sealing.Whenever the led bow strips get here i will install.
SHSU
OOOOOO, exciting!!!! Take some pictures of your splash!!!
82rude
Might be a few yet.I started on another money gobbler the old 2003 f150 4x4.Rear quarters are rusting so im temp fixing up till i decide weather to totally redo or take off radcap and drive a 2016 f150 under it,lol.
82rude
Ripped out all the wiring today and rewired the new led lights etc.What a dogs breakfast.The middle led light lights up the darkness big time.
Watermann
Yeah E WA doesn't get rain in the summer but it sure would be nice to have a little about now since it hasn't rained since the first of June.
SHSU
Looking real pretty there!!!! Are they imbedded in the rail or on the exterior?
82rude
I cut the rail and mounted them in side it.First i mounted a piece of car door bumper inside first so the led will sit out a bit further.If i had to do it again im not sure but its good as is.
SHSU
What part you not sure about?
82rude
Well now that ive had time to think about it im ok with it.It is a permanent step but those led strips are cheap with a capital cheap! I t was like 10 bucks for 4 pairs of them.Once you cut into the rail bumper theres no going back,but ive seen many youtube jobs done the same way on much more expensive boats so im fine with it now.
82rude
Well i splashed the boat today and im pleased so far.Same time on water before redo i would of took on about 3 to 5 gallons of water.I drained about a cup after splash and im not positive i got all the water out of the hull from the rain before hand so im pretty happy with the results.I gained about 150 to 200 rpms also,so i could leave as is or go to a 17p from my 16p ss and most likely id hit about 35 to 37 gps!Pre redo was 32 mph with the 16p at exactly 6000 rpm.Now with same prop i hit 6150 to 6175 rpms and almost 34mph.17p should put me comfortably in the rpm range of 6 or below.
