keep ya from itchin
osborn159
I was gathering up my goodies to go grind on her again today, in my stuff i keep a bottle of moisturiser, slather it on before grinding the dust doesnt seem to itch as bad after using this, we used some kinda barrier cream in the Navy when grinding not sure what it was worked pretty good as well, try it and let me know what you think.
F14CRAZY
Ensign
Re: keep ya from itchin
I'll keep that in mind. I wore a tyvek suit, goggles, and cartridge respirator (along with a long sleeve shirt and jeans underneath) so I'm well protected but I usually didn't wear gloves because the dust just didn't bother my hands
Signal 20
i have read a lot on here about people taking precausions when grinding and cutting glass to keep from itching, but honestly (knocking on wood) I haven't had much itching problems. I wear a tyvek style suit, gloves, googles and respirator when i'm really cutting or grinding and i'm throwing a lot of dust around but I have had acouple times when I needed to do a quick grind or cut and I didnt feel like completely gearing up for it so I just put on the respirator and googles. I have a small laundry style tub in my garage and I just walk over to it every now and then and rinse off my arms, face, neck and whatever with cold water......havent had any inching problems yet ;)
Ayuh,.. Anything you can put on to keep the dust off your skin is a Big plus...
Also, when done,... Start your shower a tad Colder than normal for the 1st rinse off,...
Getting rid of most of it before cranking up the Hot water, keeps it outa the skin's pores...
Spinnaker
Lol, you even have showering down to a fine art.:D
Another thing is if you've already gotten the "itch" say on your forearms you can use duct tape or any really sticky tape. Just put it on and pull it off a few times. It sounds like self abuse but it really helps relieve the itch by pulling out embedded micro fibers. ;)
osborn159
not a replacement for suiting up properly, just for exposed areas suit doesn't cover.
tallcanadian is pr88 the barrier cream?
D
Spinnaker
D
That was me that said PR88, and yes, it is.
jspano
:eek:
i'm alittle hairy, i don't which would be worse, fiberglass or de-hairing:p
Spinnaker
:eek:
:eek::D What about the underside of your arms? I know for me it's the un-hairy parts. Wait! I'm un-hairy all over. :rolleyes:
But seriously, I get itch between my fingers and underside of my forearms. Not that you needed to read that. :rolleyes:
jspano
colin
so far we know you don't like noodles and your not very hairy and are into duck tape... HMMM!
tell us some mor..... no never mind
spin just kidding
LOL:D
osborn159
spinnaker i do appologize, read to much to fast sometimes, is pr88 or anything like it availible to the public, remember it worked better the otc moisturizer, my opinion, my sensitive spot is my face, let me know at your convenience, thx
D
stylesabu
so i need to shave my arms first?
osborn159
up to you, you can shave anywhere that works for you, although not everwhere requires shaving, my spot is my face
Spinnaker
D
Ahhh no worries. :p PR88 is available to the public. Automotive parts supply stores carry it, Industrial supply. I can't say where it is in your area though. Here it's about 25-30 bucks for a 1 liter jar. Works well but if your hands get wet it's slicker than dog crap on a linoleum floor. I have used it on my forehead with no issues to my skin. I notice in hot weather and sweating lots you need to wash and re-apply periodically.
colin
spin just kidding
LOL:D
Oh and stylesabu, no need to shave.
I have used this on my hans many times only to see black Sika-Flex wash right off with a little scrubbing. Now that is something to be said.
http://www.pr88.com/
___________________________________________________________________
Ayuh,... I've sanded,+ ground fiberglass a few times....
Obviously,... You're Not a very hairy fella, huh,..??
It would take 2 rolls of duct tape to just get down to the skin on My arms,...
Muchless Anywhere else...
Thank God, My Love really likes a Teddy Bear kinda guy, All Furry.....;)
If I could only get it to grow on my Head, instead of my back...:rolleyes:
erikgreen
Things I've learned recently doing a ton of grinding on my boat. I'm to the point of grinding the entire interior hull, and I've generated half a garbage bag of white dust so far.
1) Cover up all over with a tyvek suit or clothes.
2) Use talc or cream beforehand on exposed skin
3) Seal wrists and other loose spots with tape (I shaved my wrists for this)
4) KEEP THE DUST OUT OF THE AIR
Despite the fact that you're wearing a respirator (not one of those cheesy little dust masks) if the dust builds up in the air enough it can really make your eyes and skin uncomfortable. To the point of damage, almost.
Of course, none of the above stops dust from coming in anywhere the tape tears, or you have a hole in your clothes, etc.
If you get a lot of glass on you (IE white dusty skin color) then you're stuck with some itching. Duct tape and the like take off some fibers, but they can actually push other fibers in farther. The shower helps, as does "brushing" the stuff off with a fine fabric, but you won't get it all.
One thing that seems to help is teaching a 45 minute class underwater, for those of you that are SCUBA instructors :)
Erik
osborn159
erik, so a long dip in the pool helps, have to try that.
D
Spinnaker
Well of course I have hair on my arms but it's usually the unhairy part of the underside of my forearms that get itchy. But I get your point. Nothing like a good waxing ay? :eek:
