Niels45
Thread starter- Joined
- Jul 16, 2019
- 30
Hello,
After cruising, when engine go to idle, the engine often stops. The idle speed is 850 without load, and 650 in gear. When I put the engine from gear to free, the kill switch works, but it seems to close to long. Is that possible? And is it adjustable? Or can a bad lower shift cable cause the problem? Out off the lower shift cable I found a drip of water.
