Kill Switch
kelly t
I have a 1981 evinrude 115TLC1M in perfect condition. My question is what kind of killswitch should I install and how easy/hard is it to install.
All help is greatly appreicated.
thanks
Kelly
Re: Kill Switch
Ayuh,...
Have you got that motor mounted on a boat,..??
Is there a controller, with a Key to start it,..??
Are you mounting the killswitch on the Motor,..?? or the Controller,..??
kelly t
Re: Kill Switch
is mounted on a 17 ft Ebbtide and does have a control and key start.
Would be mounting on the controller
fdmsiv
Re: Kill Switch
If you get a metal push kill switch make sure you get the push=close otherwise you will get a nasty shock and your engine will not stop (don't ask me how I know this, just know the packaging is very similar for the switches)
