OhioWoodenFisherman
Thread starter- Joined
- Aug 18, 2019
- 3
I'm starting my 1st project boat, and as most of us budget is unknown and unrealistic but throwing a ton of time and money into the outdrive isn't something I'm ready to do, yet.......
A little down and dirty background. To the best of my knowledge the boat is a 1987 Sunbird 208 Cuddy Cabin with a 181CID Mercruiser 3.0, alpha one drive unit. Picked it up with clean title for less than I could sell the trailer and part it out, so far no worries even though I knew going it it was a complete hull up project. Had the motor running well enough that I'm comfortable with it being OK. No water thus far in oil etc. Worst case the motor is a rebuild but block and head gasket are sound. Pulled all the interior and started deck and stringer demo from the helm to the bow, no surprises there (deck and stringers are trashed) I'm completely comfortable with all of the wiring, fiberglass and woodwork (marine plywood deck and stringers etc.) Transom is also trashed. Having said that I know what I'm in for and am completely comfortable with everything fore of the gimbal housing. The outdrive makes me nervous simply because of the cost of the specialty tools. By the time I purchase all the tools to completely rework the outdrive I'm money ahead buying an aftermarket drive. I don't mind spending the money on something I'll use multiple times, but there's a lot of cash involved in tooling up to rebuild 1 outdrive and I'd rather spend that on the rest of the boat.
Pulled the alpha one gen 1 outdrive today in preparation of pulling the motor. Signs of water intrusion immediately, water dripping between the outdrive and gimbal housing seal. Universal joints have surface rust only on the flat round posts (sorry still learning nomenclature). Drained the oil off the lower unit and plenty of water and bad grease smell. Skeg is pretty banged up and anti ventilation plate has 2 good sized chunks taken out of it, holes from the hydrofoil plate, one of which is a bolt that basically pulled thru, and a new one from Mr stupid (me) trying to drill off the fin anode as the bolt holding it on was stripped.
I haven't ventured into the upper gear case yet but I'm not optimistic. Good news is I can manually turn the drive spline and manually engage the shifter and prop shaft easily turns in forward and reverse.
Basically what I'm asking for is reassurance that an aftermarket drive at plus or minus 2 grand Is going to last.
Yes I'm an idiot, but I'm comfortable with that
