FJ_Russo
Thread starter- Joined
- Mar 14, 2010
- 350
So I did a complete seal replacement on my 1968 65hp manual shift Johnson, Prop shaft, drive shaft and the middle o-ring seal. I used every seal that came in my I-boats seal kit. And I'm still leaking. I have replaced the nylon washers on the drain/ fill screws also. I'm confused anyone with any ideas.
While she is running I can see oil coming out from underneath the cavitation plate. the slot there that they suck water up from and when I drop the lower I have milky oil all over the inside lower unit leg, making me think its a drive shaft seal problem.
I'm stumped and looking for someone to bounce some ideas off of.
Thanks a ton.
Thanks a ton.
