Laddies please help throttle cable broke
Rowboat
Here are some pic's of my control box .It is a 1998 searay F-16 jet boat there is no identifying marks on the control so I don't know what make it is. The cover is plastic and I can't pry it off . Any suggestions would be appreciated.
Laddies
Banned
Re: Laddies please help throttle cable broke
Rowboat, Without knowing what you have, the only thing I might suggest would be for you to go to the accessorie section on BAM Marine site to see if it is one of the boxes that Mercury built, the you can let us know the model. If it's not one of theirs try Teleflex/Morse site, just anouther thought would be try the P.W section or Searay section here or see if SeaRay has a parts site on the web? Wish I could be more help but I have never serviced P/watercraft their just to much hassle for us old farts--Bob
JUSTINTIME
no pics work
i have the mercury look up manual on my computer
i just need hp please
Rowboat
It is a 175 HP v6 mercury and ty I will look up sites sugested
JUSTINTIME
u should have 3 screws holding it in
Rowboat
Thank you Eric. I'll try this again.
Laddies
Banned
OK, thats a teleflex control. First remove the cables at the engine (unless there is enough slack to pull the control head from the gunwale) next move the control rearward an d remove the front of the box from the hole, then side the box forward and out of the hole, there should be 2 yellow or yellow/red wires going forward out of the box, they are wires for neutral shift switch, if the is enough slack you will not have to disconnect them, probably not I usally cut them and refasten with stake ons DON'T LET THEM SLIP AWAY. Then on the back of the box the cable is held on with a cotter pin and held in place with hinged fastener, Be sure to fasten the broken cable to the new one or a fish tape to help the reinsallation of the new one. Sorry about the delay hope this helps--Bob
Rowboat
Thanks for the help and suggestions everyone I haven't givin up just hard finding time to work on it ,winterizing and all will get back to it soon ,still can't get box out of hole in boat but I will post results
BOB
Rowboat
WOW do I feel dum ;:% I got flash lite in behind control box and found that cables were jammed up on gunwhale therefore wouldn't let control box move out on front enough to move forward . I really appreciate the help and contacts you boys gave thank you very much again
Bob
