Cadillac-ack-ack
Thread starter- Joined
- Dec 1, 2017
- 104
The Lark power-head is going together well. I'll be ready to install it back on the lower-unit soon, probably tomorrow, however I find myself with no specialized 'marine grease'. Separating the head from the shaft was easy with a little wiggling but the internal splines of the crank showed corrosion and were dry. Stainless external shaft was fine. I spite of the crank spline's rust it cleaned up well and the teeth are sharp. My question is will All Purpose HD automotive grease be OK to use on the crank to shaft splines? There should never be water there. - Pete
