late 80s early 90s merc 90 hp control question
philipjames5k5
There are two harnesses coming from my control box. One big main harness and a small 5 prong harness small harness. What is the little harness for.
philipjames5k5
Re: late 80s early 90s merc 90 hp control question
Not sure where you are getting. My friend just purchased a motor with controls and the harness is coming out of the control box by about twelve inches. And the motor he purchased does not have the harness attached to it so what is it? Is it needed? Just looking for a little help.
oldman570
Your control should have a large long harness about 15' or so long that goes to the motor and a small one that can be hooked up to a tach and it should have a 12 volt + and - wire in it for power to the gauges. A picture of the control and all the wires would help us get you more info.
Oldman570
philipjames5k5
Thanks Oldman I appreciate it. I just found a diagram after hours of working. It is for the tach. Its weird because I jave a few years newer motor and it doesn't have this cable. But I also don't have a tach
