I dropped the deck back on, and it doesn't fit...
Everyting is ok except the bow. It looks like the bow settled in on the bow roller & is approx 1 inch in from the deck lip.
I currently have pulled it out with an eye bolt and haqve screwed everything together. The deck and hull have 5200 in there to replace the staple that were applied at the factory.
There is significant pressure on that strap, and I am terribly afraid that as soon as I release pressure the screws will simply pop through the glass & I'm still hosed...
On to the question.
If I let it sit like this for the winter, will the bow take a "set" in the current position, solving the problem? Or do I need to pull the deck back off & cut the joint between the floor & hull allowing the hull (bow) to move forward and release some of the pressure that way?
Or is it hopeless...
Rest of the project pics (you have seen) at http://picasaweb.google.com/mckevin32/BoatProject
On to the question.
