Hey maties,
I have a 1984 rude Mod# E70TLCRD. I have a couple of ?'S
1. There is some gear oil seeping out of the lower unit, a friend of mine told me that those older motors always have a bit of seepage and I shouldn't be concerned. It is not milkly in color but it seems to me, if oil is getting out then water is getting in. Should I change the seals?
2. I have rotary steering which seems to be skipping or slipping when under pressure at high speed turn etc. Is there an adjustment that can be done? Everthing seems tight. Though after taking it out this past weekend I noticed the pivot point where the motor hinges on the transom, seems to be missing a bushing because I can move the pivit point up and down on the starboard side. Would this be the culpret?
Thank you in advance.
