Are you positive it is in fact lu oil and not carbon, an unburnt fuel/oil mix? Check the FAQS for a thread entitled "Oil Leaking around Lower Unit" by IWombat and have a read.
Checking the level of the lu oil will also indicate if there is a leak. If the oil is a milky white, there is water intrusion and you will need to pressure test to isolate the leaky seal, or simly re seal all together.
Do you have a service manual?
thanks not sure about fill and drain screw replacement as i bought it 2nd hand.Were the drain and vent screws replaced along with the oil??? The reason Im asking is that this is a likely spot for water intrusion, and by far the easiest fix.
To pressure/vacuum test a lower unit:
a) drain the gear oil
b) use an appropriate adapter with a gauge tee'd in to apply pressure or vacuum(I have rigged a set up using the adaptor from the lower unit oil pump fitting). No more than 15 psig for pressure. You can use a bicycle pump or any other compressed air source for pressure. For vacuum, you need a vacuum pump.
c) LU should retain some pressure or vacuum for 45 minutes minimum.
d) If pressure doesn't hold, submerge LU in water (or spray with soapy water) to find leak source [possibilities: drive shaft seal, prop shaft seal(s) (usually two), shift shaft seal and the fill/drain screw washers.]
e) replace offending seal(s) as required.
thanks, i had someone on this site post a website to find parts on do you know where i should look?OK then before you pressure test it, change the lower unit oil, along with new gaskets for the drain and vent screw. Use full synthetic. Take it for a test run, then back off the drain screw, allowing some of the oil to exit. The water is heavier than the oil, and will sit at the bottom of the gearcase, exiting first. If it is still milky, then look into a re seal. If not, the intrusion was likely at the gaskets and the problem is solved.
thanks HT thats the one, i will bookmark it. i will follow up later.Regarding the crush washers (gaskets) go to your local Johnson/Evinrude dealer and grab a handful of them to keep as stock. If you do not have one local, the actual part number is 0311598.
Here is a link. Follow the prompts to your particular model, then click on gearcase to view the exploded diagram and parts list.
http://shop2.evinrude.com/ext/index.aspx?s1=91d8a7b684b84e2c471559d073367b54
