wellcraft-classic210
Master Chief Petty Officer
- Joined
- Sep 22, 2010
- 839
The problem statement:
On our Merc 260 ( 350 v8 with Quadrajet ) ) alpha 1 in a 1983 Searay SR260 I have had a lack of fuel issue at startup until the system builds pressure. This gets worse if the boat sits over 1 week and has been that way for some time now // However-- this season its getting worse.
Details
Starts right up if used in the last day -- Divorced Choke works OK if over a few hours // Runs great once started
Need to crank for about 10 seconds if the boat sits for over a week. ( Last 2 years I had this issue but not as bad -- maybe 5 seconds max )
I suspect that the Carb leaks via the passage plugs and also that the anti siphon is leaking as the cranking needed for over 1 week without use has increased.
My plan
1) I just ordered a new anti siphon valve as they are fairly low cost and an easy change-out. ( it was clean on prior checks and i suspect it may be scored or worn, )
2) I need to do something about that Carb -- ( Winter project ??? )
3) I should check the fuel pump pressure -- but that seems to be enough to supply the engine at full throttle so I don't think that's the culprit
My question is
-- Has anyone had good success sealing a leaky Quadrajet by using set screws and epoxy to seal the passage plugs or by any other method ?
I would like to try and fix this before switching to an Eldebrock carb -- But open to advice here. Their seem to me some mixed reviews on a successful fix to the passages.
Any other input is welcome -- Thanks in advance !
Details
My plan
My question is
