rchapa28
- Joined
- Mar 5, 2012
- 18
Need help..... Not having great luck today trying to lift front of boat from trailer using floor jack tried several different methods .. The end result is that In lifting the front of the boat trailer is lifting also!!!.... Which is "NOT"
suppose happen. :facepalm:
I need to replace a damaged roller from trailer.
The way i thought of doing this was placing brick block and floor jack below with cut of wood front area of boat raise jack jack
As floor jack arm raises the front of boat raises as well.. Back tie downs n transom saver are not attached :facepalm: :facepalm:
Not sure why it lifts sure its simple but i'm complete amateur .... Any clues
