Lift boat from trailer
rchapa28
Need help..... Not having great luck today trying to lift front of boat from trailer using floor jack tried several different methods .. The end result is that In lifting the front of the boat trailer is lifting also!!!.... Which is "NOT" :mad: suppose happen. :facepalm:
The way i thought of doing this was placing brick block and floor jack below with cut of wood front area of boat raise jack jack DSC00109.jpg
As floor jack arm raises the front of boat raises as well.. Back tie downs n transom saver are not attached :facepalm: :facepalm: DSC00110.jpg
Not sure why it lifts sure its simple but i'm complete amateur .... Any clues
smokeonthewater
Re: Lift boat from trailer
you need to attach the trailer to a tow vehicle OR put blocks or jack stands under the back of the trailer... you aren't lifting the trailer, you are tilting it because by jacking up the front you create a condition where the trailer has more weight on the rear
rchapa28
The one trick i did not try was hitching to my truck? Not sure if that is answer .... read you response but i will have to try later this evening I will post pictures with progress
coolbri70
that should work, i put blocks at rear corners of the boat, with the hitch down, then used the trailer jack to raise the front, then i put blocks under the front and lowered the hitch. my boat was 3" over the rollers, using only the trailer jack
90stingray
Is the winch strap loose? I would try hooked up to the tow vehicle as the weight on the rear of the trailer might be raising the tongue. But check that strap!
tpenfield
One of the more 'popular' ways to lift the boat from the trailer is to lower the tongue as far as you can and then block up the stern at the transom corners. Then when you lift the front of the boat with a jack, you are actually lifting something rather than tilting the boat backwards.
You can Google some pictures and videos of folks who have lifted their boat and even removed it from the trailer.
gm280
I certainly can't tell for sure but are you only changing the roller and nothing else. I ask because from your first picture, it looks like there is some serious haul damage in that area as well... Just thinking out loud!
SWD
One of those folks would be me. Just did it about 4 weeks ago. In your case if you are just wanting to replace the roller then attach the trailer to a heavey vehicle and then use your floor jack.
rchapa28
gm .... Yeah it's a boat I'm working to restore but I'm starting with the trailer before breaking into other areas of boat so yeah I hitched to truck sadly results r same note its a trailer that breaks in two parts not very certain what that is referred to ... so boat lifts from winch area a good 2-3 inch.
briangcc
A trailer that "splits" in two is a tilt bed trailer. So my first very stupid question for you is...is the pin in the tilt bed so it can't tilt? To me, and its difficult to tell, it looks like your tilt pin is sitting on top of the trailer tongue between the forward roller and your winch post. Is that correct? If so, insert it please :joyous: and try again.
Also, if you're still having issues getting the boat off the trailer, here's what I would do if you're just replacing that forward roller....
1. Use the setup in Photo #3.
2. loosen the bolts on the brackets holding the roller to the boat trailer frame.
3. Disassemble and reassemble with new roller.
rchapa28
A thousand thanks for the help I was a lost their :) :) I few pics to help respond
DSC00120.jpg this is pin suspecting its a factor?
DSC00121.jpg bolts from this bracket?
DSC00122.jpg I will be changing to this winch post a few updates in budget prior to getting to boat restore :watermelon:
smokeonthewater
if the boat is lifting from the winch post then it is working..... keep going with the jack
smokeonthewater
Time to rethink things a bit......
something else just occurred to me... that roller is so new that it still has the sticker on it but is already split.... it may be seriously overloaded due to incorrect bunk and roller adjustment on the rest of the trailer... lower the tongue jack all the way and block the stern of the boat and then raise the tongue jack all the way and block the keel at the front and lower... this should have the whole boat hovering just above the trailer.... more jacking may be needed if not... THEN adjust the whole trailer so that the bunks and rollers are all the same distance from the boat and replace any broken ones at the same time.
rchapa28
Well I won't abomin boat but i will trailer after to many tries. :mad:
rchapa28
Think I meant to say, "Well I won't abandon boat but i may abandon trailer after to many tries."
smokeonthewater
ahh gotcha... read my post again... I'm not at all suggesting abandoning anything... just suggesting that you need to adjust the whole trailer so that the new roller doesn't split before it's sticker can get worn off also
colbyt
Master Chief Petty Officer
I've looked at all you pictures. It looks like you have a tilt trailer and I suspect when jacking the weight on the back of the trailer is causing it to tilt. That should not be happening unless the tilt lock pin is defective.
As a temp solution you might be able to clamp the 2 sections together with a u-bolt or big c-clamp. I strongly suggest that fix the lock pin before you tow or launch the boat again.
gnathv
Looking at picture 3 of post 12. Does the brake actuator have 2 bolts through the trailer frame or just 1?
