Lights flashing ONLY when vehicle’s night time lights come on
Patrick_L
When it’s time for car’s headlights/tail lights to come on, trailer’s lights are flashing. During the day, it’s all good. I have a flat 4 pin set up and upon testing using 4-way light tester (left, middle, right diode), i get:
press brake: middle & right diodes light up
left turn signal: middle diode lights up
right turn signal: right diode lights up
headlights on: left diode is flashing
Any ideas ?
Wrong harness kit ?
Harritwo
What is the tow vehicle? Is the tow vehicle wired at the factory or is it a plug and play or wired by an individual?
Have you hooked it up to a different vehicle to see if it reacts the same.
Your test indicates something isnt kosher with the headlights
Patrick_L
Harritwo 2008 Infiniti FX35. Wired by an individual using harness kit (car did not have tow package nor was wired in) and no i did not try another vehicle.
Harritwo
Test with another vehicle. There should be NO FLASH with the headlights. You may have a wrong plug & play kit.
Harritwo
Test with another vehicle but I believe the plug & play kit is the wrong kit. There should be NO FLASH with headlights. Brown wire of your flat 4 is tail lights and can be tapped into at the tail light or license plate light. I like the plug & Play but it has to be for your vehicle. The converter could be bad or wired in wrong if it isnt part of the plug & play.
Harritwo
Patrick_L
Harritwo that’s what i thought too. Likely it’s the harness kit. I looked up #46155 by Hopkins and i hope it will take care of it 🤞🏼
Also i will do it myself this time
isaacs
Are the brake lights on your car separate from the turn signals? Because that is what that Hopkins unit is for.
Wiring them can sometimes be trickey--I used one on a Hyundai Santa Fe and I remember doing a lot of modification to the original trailer connector
First off, make sure your ground is good on both the car and trailer.
Second, the flashing you describe is kind of an unusual symptom. Does your trailer have several incandescent running lights? I'm thinking that the current draw is more than the converter can handle and there is some kind of circut breaker that keeps blowing and resetting itself. This can easily be corrected by changing the main bulbs on the rear of the trailer to LED, thus lessening the current load.
Good luck!.
