Bt Doctur
- Joined
- Aug 29, 2004
- 19,532
Evinrude E175FPXSSR
Have a overheat on a customers motor and I`m not that familiar with these.
changed wp kit, no damage seen
changed thermoststs ,no change
ran with thermostats removed, no change
dropped lower unit and put hose directly to the water inlet tube.
No change to the overheating at 1000 -1200 rpm. very good water out the tell-tale hole with muffs or direct to the water tube.head temp climbs steadily to 200 deg.within 3 minutes
Removed port head, no clog/corrosion found. Of course 1 sheard bolt
Stumped??????????
links to service manual by private message appreciated
Suspecting a crushed water inlet tube due to very little water coming down with the exaust.
Does the water tube simply pull down and out or is powerhead removal required
Thanks for any help
Bt Doctur
Stumped??????????
Thanks for any help
Bt Doctur
