drop the GC
remove pump cover
replace impleller ...bit of sop or greas to slide it in the pump housing turning clockwise looking down
take care not to pull out the drive shaft !! ... slide the pump cover up & past the o ring on top reverse procedure to install replace oring
install small impeller key !!
