Location of impeller 1971 Johnson 4HP weedless outboard
SOG3
Need to know the location before I tear into it !
Sits on top of lower unit.---Just 4 screws to pull it off.----Rest is obvious.
Crosbyman
drop the GC
remove pump cover
replace impleller ...bit of sop or greas to slide it in the pump housing turning clockwise looking down
take care not to pull out the drive shaft !! ... slide the pump cover up & past the o ring on top reverse procedure to install replace oring
install small impeller key !!
SOG3
Thanks guys, have a great day !
