Piece715
- Joined
- Jan 26, 2009
- 757
I have posted these questions in my restore thread in my signature but figured i'd shoot them towards the experts. This is copy and pasted so ask if ya need some clarification on anything just shout. Please correct me as I'm sure i have messed something up, but hey that why they call it a learning process. Thanks in advance
Ok im in the process of buying wire. Going with 2 six gallon tanks the splashwell is filled. The 12 gallon tank would not fit in the splashwell. This situation has forced me to move the batteries to the bow seating one in front of each console. The question is what gauge wiring will work for this set up? I know people don't recommend this set up but i have no other choice and it will distribute weight well. The run im guess would be around 12 feet and that is prob an over estimation. I am not sure how many amps the starter draws either. The motor is a 50hp Evinrude model E50 BELCO. Now the set up includes a blue seas fuse block and a battery switch.
This is the run down of the wiring as im seeing it; Just need confirmation or ideas for better set up. The runs will be from battery to battery switch (2-3 foot run), from battery switch to fuse block (1-2 foot run), the direct run for the battery to motor is about 12 feet.
The cranking battery will be run in parallel to the deep cycle. The batteries will then be wired to the switch like so
All loads will be wired to the COM which will be the engine and the fuse block. Does the negative in the picture going from engine to bat 1 also do this in my set up and then a neg wire run from neg bat post to fuse block?? guess confused how to incorporate the fuse block and switch. The positive will go from COM on isolator switch to positive on fuse block with a master power toggle switch in line like so
How would stereo work into this? Would i want to run it through the fuse block or just wire directly to batteries as the system requires inline fuses from batt to amp.
OK i think im confusing myself. SOMEONE please help
I know this was a large post. If ya need clarification on my thoughts please ask. Im needing recommendations, suggestions, diagrams, etc. I have saved all the stickies in the electrical section and know what gauge wire I need for everything except the long run of battery wire. Guess the other main question is a general run down of wiring all the components: dual batteries, an isolator switch, fuse block, and amplified sound system. Thus concludes my jumbled novel! thank u will be here all night !
EDIT: Just had a moment of clarity. Im guessing the audio system would be wired to the COM port for positive with the ground running to the fuse block? The positive will still have an inline 50 amp fuse as recommended for the amp. This sound correct?
Ok just got back from looking at the boat. It looks like the 12 feet is pretty much the run of the engine to batteries. Also the two batteries will need a 6-7 foot run between them to run in parallel.. This possible? I understand the + end of the wiring now that i have looked at the wiring diagrams for the two pieces but still confused on the ground set up and the wiring of the amp into this set up.
Here are the pics of the installation instructions on the fuse block and isolator switch:
The switch according to installation instructions recommends 4/0 AWG per terminal. Will this be enough despite the long runs?
Thanks again
I have search around and read the threads I could find on long runs of wire but most just turn away from the venture due to cost but this is the direction I have to head... at least from how i see it.
Thanks again
