Looking for a little more power
180shabah
Re: Looking for a little more power
ZZ3/4 cam specs:
PN 10185071
Duration @ 0.050" int 208* exh 221*
Lift with 1.5 rockers int .474" exh .510"
Lobe Centerlines 112*
Sounds OK to me, but with 400 ft./lbs. of torque, he is gonna want a Bravo behind it.
But that should definately move that deck boat :D:D
CharlieB
Ditto the headwork, careful picking a cam, roller rockers.
Edelbrock makes an intake for the 4.3, call them and ask if it's available in the 'marine coating'.
If you'd real serious about a little more power add a freshwater cooling kit and aluminum heads.
A centrifugal blower such as the S-10 kits could be used without too much hassle, just $$$$, Only consider one with a heat exchanger
If you're REALLY serious
D. ALL THE ABOVE
JoChek219
what about switching to vortec heads and intake..... might make 25 more hp or so.. just an idea
Glenn and his VIP
Im thinking hard here, its winter time and I would like to do something before good weather is back. I want a easy task, dont want to really pull motor, I would love the blower idea if it wouldnt hurt my existing motor. Anyone have a blower links, I want to buy the right stuff. I was just giving a S-10 blower idea because I found that the made one for a truck. What ever I get will be Marine rated. Thanks so far for all the ideas.
After a thread with 44 posts,+ you Still havent figured out that you Can't get Something,....
For Nothing...........
:rolleyes:
Glenn and his VIP
:rolleyes:
Not lookingforsomething for nothing, I would just rather stick a blower on and be done with it, than pulling motor and installing a V8.
When installing Any kind of Blower,....
The motor needs to be Set Up properly for the Extra Boost......
Your motor is Not Set Up Properly........
Going to a Blower,.... or Nitrous on a Stock motor,...... Will result in a Pile of Broken Parts..........
I admit I haven't read All 44 posts,.....
But this Must have been mentioned Somewhere above.......
Glenn and his VIP
Im leaning to the V8, I have found 1 online.... Do you recommend a sponsor from here that sells complete engines, I need everything that I cant use from my V6.
180shabah
I think that is a much better choice than a blown 4.3, and you should be fine using an alpha drive with 1.5(1.47) gear ratio.
CharlieB
I just threw away the new mailer that came from procharger, among their applications they list 'Marine' kits.
I had great sucsess with blowers on factory camshafts but I limit boost to 6 psi and back off the timing (total) 4 degrees.
I have a Roots style Magnuson blower on my Harley Shovelhead since winter 79 but the rest of it isn't much stock either, altho the pistons ARE factory H.D. 8.5 to 1.
A blower (centrifugal) does cost but if you consider the power to weight ratio for the dollars spent, you can't beat it for safe horsepower. Cost comparable to a V-8 but without the added WEIGHT!
Nitrous is the only cheaper alternative, but it is NOT safe for engine reliability or longevity.
I still vote for
ProCharger kit @ 6 psi max
Freshwater cooling kit (so you can NOT worry about electrolysis)
Alum Heads
Alum intake
Camshaft @ 218 intake 228 exhaust, lobe centers no tighter than 112, actually 114 would take more advantage of the boost and develop MORE torque
180shabah
114 degrees???
What about reversion?
